Difference encapsulation ppp/hdlc
Answered Question
Dec 4th, 2007
Can you tell me the difference between the encapsulation ppp and hdlc or show me a web site where i can get this informations.
Thinks
Correct Answer by shivlu jain about 9 years 1 month ago
HDLC is used on point-to-pont serial links suc as T1s, DS3 and now
Packet-over-SONET (POS). It has a low overhead in terms of the
additional bytes required over and above the layer 3 payload. There is
no authentication protocol for HDLC.
PPP was and is heavily used in async dial-up and provide for
authentication using PAP or CHAP protocol. Now there is also PPP over
Ethernet (PPPoE).
A variation of PPP known as multi-link PPP (MLPPP) is quite popular for
loading balancing parallet circuit like T1's.
regards
shivlu
Overall Rating: 3.5 (2 ratings)
Correct Answer
shivlu jain Tue, 12/04/2007 - 00:10
Ethernet (PPPoE).
regards
shivlu
bvsnarayana03 Tue, 12/04/2007 - 00:13
On routers, hdlc is the default encapsulation method available on interfaces. It doesnt provide authentication while ppp provides authentication so can be used isdn configs.
