Weird Problems On Cisco 2610 Router
tolgatanriverdi
Hi In our company there is a 2610 router that connects two branches of our firm but more than 2 weeks there is a weird problem(we didnt change anything on it) router doesnt route some ip addresses
ip address of the router is 10.0.0.4
it has a static routes such as
ip route 0.0.0.0 0.0.0.0 10.0.0.6
ip route 62.41.66.0 255.255.255.0 212.50.38.49
ip route 172.16.0.0 255.255.0.0 10.0.0.6
ip route 192.168.1.0 255.255.255.0 1.0.0.2
ip route 212.50.38.100 255.255.255.252 1.0.0.2
but for example it doesnt route this ip address
62.244.241.54
when i ping this addres via this router it gives
10.0.0.4 : destination host unreacheable
does anyone know why can it be?
18 Replies 18
Jon Marshall
Can you check whether you have "ip classless" turned on.
Jon
ip classless is turned off with
no ip classless
line
Okay, that is your problem.
62.244.241.54 should be routed using the default route entry ie.
Trouble is you have a route for the major network 62.x.x.x in your routing table. It is using a class C subnet mask but it is still a class A address. So the router looks for a match on the major network number of 62. for 62.244.241.54. It doesn't find an entry but it can't use the default-route because of your "no ip classless" command.
So enter "ip classless" and it should then route that destination to 10.0.0.6 which is the next hop for your default-gateway.
Note that this will only happen for 62.x.x.x addresses. If you try 61.x.x.x then it should route to 10.0.0.6 anyway.
Hope this makes sense
Jon
But I tried that and it didnt work
I made
configure terminal
ip classless
reload
and still the same problem
may it be hardware of router related problem?
From your mail it looks like you did not save your configuration before the reload, so when the router rebooted it had reverted back to "no ip classless" and so you still have the same problem.
Also why did you reload?? This is a Cisco router not a PC running a Microsoft OS, so there should be no reason to reload the router after a change to the network configuration.
Just try the following and see if it works,
Router#conf t
Router(config)#ip classless
Router(config)#exit
Router#wr (or "copy run start" if you prefer)
Then test your connectivity.
Best regards,
Michael
As Michael says, did you save the running config. You definitely don't need to reload the router.
If you do a "sh run" make sure that you cannot see a "no ip classless" statement. If you can
router(config)# ip classless
router(config)# wr mem
then try your ping
Jon
hdt
You could try the following:
turn off route-caching / cef on all interfaces.
create a numbered acl which matches your test traffic.
then debug ip packet detail (with term mon if connected via vty)
The output of the packetdump could shine some light on your problem,
regards,
Henk
mheusing
Could you provide the output from "show ip route" of your 2610?
Tha might help to understand the problem.
Also be extremely careful before using the troubleshooting path suggested by Henk. Make sure your CPU is not overwhelmed and also make sure that CEF is not needed for any feature you are using!
Making a mistake with Henks approach can easily crash your router (though you do not seem to have an issue with frequent reloads ...).
Regards, Martin
here is the output of my cisco 2610's show ip route
Gateway of last resort is 10.0.0.6 to network 0.0.0.0
1.0.0.0/24 is subnetted, 1 subnets
C 1.0.0.0 is directly connected, Serial1/0:0
S 172.16.0.0/16 [1/0] via 10.0.0.6
C 10.0.0.0/8 is directly connected, FastEthernet0/0
212.50.38.0/24 is variably subnetted, 2 subnets, 2 masks
S 212.50.38.100/30 [1/0] via 1.0.0.2
C 212.50.38.48/29 is directly connected, FastEthernet0/0
S 192.168.1.0/24 [1/0] via 1.0.0.2
62.0.0.0/24 is subnetted, 1 subnets
S 62.41.66.0 [1/0] via 212.50.38.49
S* 0.0.0.0/0 [1/0] via 10.0.0.6
Can you post the output of a "sh run"
Jon
Building configuration...
Current configuration : 1441 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service dhcp
hostname teknokent
enable secret 5 xxxxxxxxxxxxxxxxx/
username root password 7 xxxxxxxxxxxxxx
no ip subnet-zero
ip host sincan 192.168.1.1
class-map match-all TEST
match none
policy-map DENIZ
class TEST
controller E1 1/0
framing NO-CRC4
channel-group 0 timeslots 1-16
interface FastEthernet0/0
ip address 212.50.38.54 255.255.255.248 secondary
ip address 10.0.0.4 255.0.0.0
no ip mroute-cache
speed auto
half-duplex
no cdp enable
interface Serial1/0:0
ip address 1.0.0.1 255.255.255.0
encapsulation frame-relay
ip policy route-map VOIP
frame-relay interface-dlci 100
frame-relay lmi-type ansi
ip classless
no ip http server
no ip pim bidir-enable
access-list 101 permit ip host 212.50.38.100 any
access-list 101 permit ip host 212.50.38.101 any
access-list 101 permit ip host 212.50.38.102 any
no cdp run
route-map VOIP permit 10
match ip address 101
set ip next-hop 212.50.38.49
line con 0
exec-timeout 0 0
line aux 0
exec-timeout 0 1
login
no exec
line vty 0 4
login local
end
Can you just confirm that when you try to ping 62.244.241.54 you are still getting the same message ie. 10.0.0.4 reports a destination host unreachable ?
Which next hop should 62.244.241.54 be reachable through because your routing table is saying 10.0.0.6 - is that correct ?
Jon
Jon
HI ,
no ip mroute-cache
speed auto
half-duplex -------why it is half duplex...
no cdp enable
10.0.0.6 ---belongs to which router..and how is the connectivity..
satish
10.0.0.6 is our company's firewall which directly connected to 212.50.38.49(or 212.50.35.97 both are same devices)
and everything beside static routes should have to go through 10.0.0.6
and yes I'am still taking destination host unreacheable error
