Router Hangs
Dec 4th, 2007
Suddenly our Network got hanged which is cisco 3745 series.After restarting the router it went UP.
what could be the problem ?
what are the commands i can use to know the reason?
regds
Nasheer
guruprasadr Tue, 12/04/2007 - 02:23
  • Gold, 750 points or more
HI Nasheer, [Pls Rate if HELPS]
Use the below commands to verify:
#show log
#show processes cpu
#show buffers ==> To see any Failures
#show environment
#show hardware
Do RATE if HELPS
Best Regards,
Guru Prasad R
garganshul Tue, 12/04/2007 - 02:27
hi,
just checkout weather router fan are working so propely or not because it can be due to overheating. just check it.
regards
anshul garg
nasheer.ahmad Tue, 12/04/2007 - 03:09
Thanks for the response.
The error I found is below.
System returned to ROM by bus error at PC 0x60B5C344, address 0x234 at 11:47:09
india Tue Dec 4 2007
what exactly is this means ?
regds
Nasheer
Martin Schoenbacher Tue, 12/04/2007 - 05:50
probably a IOS Bug or some damaged Hardware ... for exact informations in think you would have to contact the Cisco TAC ... instead of that an IOS upgrade would proably helps.
It would be good if you can give us som informations about the actual IOS version of the device (you would get it with sh version).
nasheer.ahmad Tue, 12/04/2007 - 05:58
Pls find the IOS version
Cisco IOS Software, 3700 Software (C3745-IPBASEK9-M), Version 12.4(4)T, RELEASE
SOFTWARE (fc1)
garganshul Tue, 12/04/2007 - 20:39
please tel me first what error exactly come when ur cisco 3700 series hangs
