Blocking Skype - Missing Commands ??
Hi All,
I`m trying to configure the blocking of Skype on a 2851 running the latest downloading IOS on the advanced security train.
I've found two documents on the main cisco site, one suggests to use "match protocol skype" - which doesn't exist (the protocol), the other says to use flexible packet matching using the "load classification" command, which also doesn't exist.
In regards to the first command, the cisco PDLM download site has a readme for Skype blocking but no actual PDLM.
Both documents reference various 12.4T releases of IOS however I'm unable to downgrade to the specific versions mentioned due to these now being deffered.
Does anyone have a working config to block skype or can tell me how I can access to the missing commands ?
I think this may the job for a TAC case but thought I'd ask in the interim.
Chris
