guruprasadr Tue, 12/04/2007 - 02:18
  • Gold, 750 points or more
HI Vidyaprakash,
I hope reliability parameter is related upto the next HOP.
Do Rate if HELPS
Best Regards,
Guru Prasad R
vidyaprakash Tue, 12/04/2007 - 02:22
Guru,
Are you talking about physical next hop(it can be modem or mux) or L3 next hop ( other end of router)
bvsnarayana03 Tue, 12/04/2007 - 05:46
  • Silver, 250 points or more
It is from cable connecting the interface to the ISP POP at problem end.
