Univercd or Cisco product documentation DVD
Dec 4th, 2007
Hello
My main question is which documentation source I should use to prepare for the LAB. As I like to use the same to which I have access in the LAB itself.
Therefore I ordered a Cisco Product Documentation DVD (from May2007) and it looks completely different to the univercd link http://www.cisco.com/univercd/home/home.htm. This DVD looks like the Cisco Technical Support and Documentation link http://www.cisco.com/web/psa/products/index.html.
To which pages do I have access?
Man thanks
Peter
Overall Rating: 4 (2 ratings)
Collin Clark Tue, 12/04/2007 - 06:13
  • Purple, 4500 points or more
AFAIK in the lab you will have access to the online version.
peterm.schmidt Tue, 12/04/2007 - 06:57
Ahh, OK how do you access the DVD? In my case I have a file called CiscoDVD.exe and when I start this IE will open and brows (see attachment). Is this also the case on your DVD? It would be great if you could check this on your DVD.
Many thanks
Peter
peterm.schmidt Tue, 12/04/2007 - 10:00
Even when i type the in IE /home/home.htm like on your screen shot i get my screen afterwards NO UNIVERCD. Does anyone have any explanation for this or is the unvercd an old documentation structure?
Peter
