intervlan routing 3560g
zaikini_23
Hi all!
I have 3560g with EMI. I connect my PC to GEth0/3 3560g and create SVI with address x.x.x.209 255.255.255.240, on my PC address is x.x.x.210 255.255.255.240. I add Linksys SRW224G4 to GEth0/2 port 3560g. I have trunk between 3560g and Linksys. Linksys has management vlan 553 and 10.0.77.70/27 address in this vlan. I create SVI (vlan 553) on 3560g with address 10.0.77.65 255.255.255.224. Linksys has default-gateway 10.0.77.65.
3560G:
ip routing
interface Vlan201
ip address x.x.x.209 255.255.255.240
interface Vlan553
ip address 10.0.77.65 255.255.255.224
#sh ip route | i 10.0.77
C 10.0.77.64/27 is directly connected, Vlan553
#sh ip route | i x.x.x
x.x.x.0/28 is subnetted, 1 subnets
C x.x.x.208 is directly connected, Vlan201
I can ping 10.0.77.65 from my PC and I can ping x.x.x.209 from Linksys, but I can't ping 10.0.77.70 (Linksys) from my PC and I can't ping x.x.x.210 (PC) from Linksys.
I enable debug ip icmp packet, when I ping Linksys from PC or I ping PC from Linksys I'm not see anything. When I ping 10.0.77.65 from PC I see rows with echo requests and echo replies. I see is similar for Linksys.
What is problem may be?
17 Replies 17
Edison Ortiz
Assign a port membership on G0/3 for Vlan 201
switchport mode access
switchport access vlan 201
and G0/2 should be assigned to 553
switchport access vlan 553
I haven't played around with that LinkSys model but I think you are having problems with the trunk. You don't need a trunk for this configuration to work.
interface GigabitEthernet0/2
description ###LinkSYS###
switchport mode trunk
interface GigabitEthernet 0/3
description ###PC###
no switchport
These interfaces has already configured. I want use trunk, because I want connect clients to Linksys.
Hi Zakini ,
I would like to know few things..
1.you have configured same ip on 3560g on two interfaces ..i.e
interface Vlan201
and
no switchport
how come it is possible.
have you got any message saying that ip conflict or host flapping on 3560g switch...
assign different ip subnet on g0/3 and do the routing on linksys switch and check the issue...
satish
Sorry, I mistake, I try two ways. Now config is:
ip routing
no switchport
interface Vlan553
C x.x.x.208 is directly connected, GigabitEthernet0/3
I'm not have ping from PC to LinkSYS
Hi ,
Then configuration on routers must be like ...
ip routing
interface g0/3
no switchport
interface Vlan553
Pc ip's :
gateway x.x.x.209
ip route 0.0.0.0 0.0.0.0 10.0.77.66
configure default route on linksys switch
ip route 0.0.0.0 0.0.0.0 10.0.77.65.
Check the issue...
satish
Ok, but I'm not have ping Linksys from PC
Hi ,
have you configured default route on both the switches ..
why did you configure g0/3 as a routing port..
have yoy tried same thing by configuring vlan x with x.x.x.209 ip addrress...by removing x.x.x.209 from g0/3 interface.
g0/3 --- switchport mode access
switchport access vlan x.
and assign one port of 3560g in vlan x and
try to ping to linksys switch.
satish
allow these two vlans through trunk.
satish
Hi!
I have default route on Linksys and my PC has static route to network Linksys. I can ping from PC to gateway of network linksys.
I change my config:
ip routing
description ###Linksys###
interface GigabitEthernet0/3
interface Vlan201
interface Vlan553
I'm not have ping from PC to Linksys
Can you please configure the switchports as suggested ?
_________________
___________________
The Linksys may be having problems with the trunk configuration and actually, you don't need a trunk port (LinkSys isn't holding more than one Vlan).
On an invalid trunk configuration on the Cisco switch, it may be default back to native vlan 1 which is not the desired vlan on this case.
My config
ip routing
interface Vlan201
interface Vlan553
I ping from PC to Linksys. I enable span session and analyze packets. I see echo requests from pc and echo replies from linksys on gigabitethernet 0/2 (Linksys), but I'm not see echo replies from Linksys on port connected to my PC...
One more time ... Please change the interface g0/2 to access mode.
Interface vlan 553 is state to down when I changed the gigabitethernet0/2 to mode access. I see tag 553 in packet echo reply from linksys. I think the trunk work is fine.
Again, you don't need a trunk configuration between these 2 link partners. You aren't carrying more than one Vlan so please don't complicate things.
If the linksys was configure for trunking, please change it.
When you changed the g0/2 to access, did you assign it to vlan 553 as well ?
Can I see the output from typing
show interface g0/2 and show vlan after making the changes I suggested ?
New config:
ip routing
description ###LINKSYS###
interface Vlan201
interface Vlan553
sh int gigabitEthernet 0/2
GigabitEthernet0/2 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001a.a2ac.db02 (bia 001a.a2ac.db02)
Description: ###LINKSYS###
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:22, output 00:00:04, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
193 packets input, 28798 bytes, 0 no buffer
Received 41 broadcasts (0 multicast)
0 watchdog, 35 multicast, 0 pause input
386 packets output, 30374 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
sh int vlan 553
Vlan553 is up, line protocol is up
Hardware is EtherSVI, address is 001a.a2ac.db7f (bia 001a.a2ac.db7f)
Internet address is 10.0.77.65/27
Last input 00:02:21, output 00:00:00, output hang never
152 packets input, 20218 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
327 packets output, 22578 bytes, 0 underruns
0 output errors, 0 interface resets
I ping successfull Linksys from PC after changed my config.
