Martin Schoenbacher Tue, 12/04/2007 - 05:36
the clock should come from the line, yes. If this are'nt working you rably have errors on the line or some other Problems from your provider. The only thing i have in mind what can need you to configure internal clocking is when you put 2 routers back-2-back.
Have you checked the error counters with sh int and sh controller? Do you see any problems there?
