unsupported character/letter in Cisco ASA
Dec 4th, 2007
I am changing from VPN3000 to Cisco ASA but when i try to move the pre-shared keys for VPN-groups from Cisco VPN 3000 it contains the character ¤ which seems to be unsupported in Cisco ASA but supported in VPN3000, does anyone know?
The ¤ is typed when pressing shift+4
I know i can make new profiles but i have this ¤ in several vpn-groups with a lot of users.
ccbootcamp Tue, 12/04/2007 - 07:55
try this:
create your config with the special characters. put the config on a tftp server. copy the config from the tftp server to the asa. if that doesn't work, then no, it's not going to happen for ya.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
