HELP!:6513 doesn't show any "Interface is UP" or "Interface is DOWN" messag
Answered Question
Dec 4th, 2007
We have a Catalyst 6513 which doesn't show any "Interface X has changed state to UP" or "Interface X has changed state to DOWN". I have tried disconnecting cables, setting interfaces to "shutdown" state, and no message appears.
This is the "show logging" command output:
Core_Alcobendas#sh logg
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns)
Console logging: level debugging, 118 messages logged
Monitor logging: level debugging, 5 messages logged
Logging to: vty3(5)
Buffer logging: level debugging, 118 messages logged
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 165 message lines logged
Log Buffer (8192 bytes):
[100]
Please help me.
Thanks in advance.
Sergio.
Correct Answer by Jon Marshall about 9 years 6 months ago
Hi Sergio
Have you added the following config to your switch
6500(config)# logging event link-status default
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Tue, 12/04/2007 - 06:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Sergio
Jon
