2960 blocks Wireless printer
Dec 4th, 2007
Dear Sirs.
In a warehouse location I have installed 16 Linksys WAP54GPE/WAP200E access points. All these access points are connected to a 2960 switch. Due to the roaming issues with Linksys APs all the ports on 2960 used by APs are in protected port mode.
Mobile devices (Intermec CK31 mobile computers) work good in this situation.
But the customer also has wireless printer (Intermec PF4i) in his environment. I have noticed the following issues with the printer:
1. Printer is switched on, it connects to the AP (WPA-PSK encryption is used, static IP is assigned to the printer).
2. Printer is pinged from the remote server and from a laptop which is directly connected to the same AP.
3. If the printer is not used for more than 10 minutes (nobody prints for 10 minutes) then it can not be pinged from the remote server anymore. However, I can ping and print to the printer from my laptop connected directly to the same AP at any time.
4. If the printer is constantly pinged from the remote server than everything is OK, the printer is always available.
Kindly advise if protected port mode affects this situation and what can be done in order to fix the situation.
Best regards.
Alexei.
mheusing Wed, 12/05/2007 - 02:54
With the information given, there is no simple explanation of the observed behaviour. Some more questions:
1) Is the server on the same subnet as the printer?
2) Does this also occur if the port connecting the AP with the printer is not protected?
3) Are all ARP entries in the printer and its default gateway or the server (if on the same subnet) at the time the problem occurs?
4) Is the printer MAC address in the 2960 at the time the problem occurs?
Regards, Martin
AlexioUBS Wed, 12/05/2007 - 06:00
Hi Martin.
Thanks for your assistance.
I dont have the answer to all your questions.
I can only say that printer and AP are in the different subnet coompared to server (printer 10.0.26.215/24, AP 10.0.26.11/24, their defaul gateway 10.0.26.250, server has 10.0.0.22).
I will go to the site and find out the answers to question 2,3,4.
I will keep you informed about the issue.
Kind regards
Alexei.
AlexioUBS Tue, 02/26/2008 - 23:45
Hi Martin.
I' d like to update this instance.
I solved the problem by enabling DHCP address on the wireless printer (instead of static IP), started DHCP server in the printers subnet, made a reservation of needed IP to the printers MAC address and setup IP address renewal in the subnet for every 5 minutes.
Now, the printer works perfect.
