CSM-S: Synchronize SSL daughter cards
Dec 4th, 2007
I have two C6K with CSM-S in place. After I have imported all the certificates and keys on the SSL daughter card of the primary CSM-S I want to synchronize this with the SSL daughter card of the secondary CSM-S. There's a way to synchronize the configuration of the CSM-S itself described but not for the SSL daughter cards. Is there a way to do this ?
Thanks for reply.
Matthias
Jon Marshall Wed, 12/05/2007 - 06:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Matthias
Unfortunately as far as i know there isn't a way to do this because the 2 ssl daughtercards can't "see" each other as such. So you need to manually load the config onto the second card.
Jon
