Not seeing certain traffic in NetFlow cache
Dec 4th, 2007
Could anyone explain why I do not see the pretty constant traffic between a remote IP camera and the backend in NetFlow cache, but I do see the icmp traffic once I ping the camera?
Jan Nejman Tue, 12/04/2007 - 11:50
1. Where are you checking netflow traffic? On the collector or on the router via show ip cache)
2. Did you enable netflow on all interfaces? If you have 6500/7600 also enable mls nde ...
Kind regards,
Jan Nejman
Caligare, Co.
http://www.caligare.com/
yjdabear Tue, 12/04/2007 - 12:58
I'm looking both on the router and on the collector (GUI). On the router, I'm using "show ip cache verbose flow" and "show mls netflow ip [source/destination]", which show the icmp traffic as soon as I start pinging.
NetFlow is enabled on all interfaces, and in both software and hardware cache.
Jan Nejman Tue, 12/04/2007 - 13:31
If I clearly understand, you are able to see icmp pings on your router but not in collector GUI. Is it correct? Could you send me output of the:
show runn | inc mls
show runn | inc flow
Thank you,
Jan Nejman
Caligare, Co.
yjdabear Wed, 12/05/2007 - 11:22
Jan,
You misunderstood. I see icmp pings (generated by myself) on both the router and the collector GUI. The problem is I don't see the alleged video traffic on either the router or the collector.
show runn | inc mls
mls aging fast threshold 64
mls aging long 128
mls aging normal 64
mls flow ip interface-full
no mls flow ipv6
mls nde sender version 5
show runn | incl flow
ip flow-cache timeout inactive 64
ip flow-cache timeout active 3
no mls flow ipv6
ip route-cache flow
(repeat for each interface)...
ip route-cache flow
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination xx.xx.xx.xx 9###
