Management authentication with MS IAS
Dec 4th, 2007
I tried to set up the management authentication ti use an IAS server.
The IAS server accpet the authentication but the controller does not give me access.
I think it is a privilege problem.
In the message log of the controller i had this :
"Dec 04 17:31:42.326 ews_auth.c:1968 EMWEB-1-LOGIN_FAILED: Login failed. User:testradius. Service-Type is not present or it doesn't allow READ/WRITE permission..."
gmarogi Tue, 12/11/2007 - 10:21
I think the problem is related to the Service-Type attribute configuration in the AAA server. In the IAS server, you need to configure the IAS server management user with a service-type attribute to administrative. Then the particularf user would be able to perform read/write into the IAS server.
Trending Topics - Security & Network
