FXO port rollover?
Answered Question
Dec 4th, 2007
I have a 2811 router with CME 4.2 loaded, using 4 port FXO card. I started with just one analog phone line for the office, but now have an additional one. How can I get incoming and outgoing calls to move to which ever line is available?
Thanks.
Correct Answer by Paolo Bevilacqua about 9 years 1 month ago
Hi, use trunk groups.
voice-port x/y/z
trunk-group pots
connection plar XXX opx
dial-peer voice 100 pots
trunkgroup pots
Then you can do certain settings (translations, hunt scheme) under "trunk group pots".
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Tue, 12/04/2007 - 10:10
voice-port x/y/z
trunk-group pots
trunkgroup pots
jstemke Tue, 12/04/2007 - 11:45
For the incoming calls to rollover, you will have to have the phone company setup a hunt group on the POTS lines.
