asa 5510 won't pass web traffic
Dec 4th, 2007
I have a problem with my firewall, I've followed all the information on the cisco site about how to allow a certain set of ports. But I still can not get to my web server on my dmz, I have even created a acl that allows all. But I can't get by the implicit deny acl.I have the correct static nat and access-group according to cisco site. So i'm not sure anymore. I didn't original build this box, and I'm not security person so I've become quite frustrated.
Jon Marshall Tue, 12/04/2007 - 10:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Could you possibly post the config.
Assuming access is from outside as an example
Web server on DMZ = 192.168.5.10
Outside interface of ASA = 195.166.71.10
static (DMZ,outside) tcp interface 80 192.168.5.10 80
access-list from_outside permit tcp any host 195.166.71.10 eq http
access-group from_outside in interface outside
The above example assumes you are Natting the private address of the web server on the DMZ to the IP address of the pix outside interface.
Jon
bmarlin Tue, 12/04/2007 - 10:43
Thank you Jon
Here is static nat I used
(DMZ,outside) 69.11.97.143 192.168.2.249 netmask 255.255.255.255 .the only difference from u but like cisco config on cisco web site
I will send you my latest config
thank again!
srue Tue, 12/04/2007 - 11:19
  • Blue, 1500 points or more
clear configure access-list DMZ_access_in
access-list outside_in permit tcp any host 69.11.97.143 eq 80
access-group outside_in in interface outside
bmarlin Tue, 12/04/2007 - 11:23
thanks 4 your help srue
I now am getting syn timeouts and Dney tcp from Dmz to outside
then asa is tearing down tcp connections here is up dated config
srue Tue, 12/04/2007 - 11:33
nat (DMZ) 101 0 0
in your current setup, you cannot initiate traffic from your dmz to the inside, just fyi.
bmarlin Tue, 12/04/2007 - 12:48
unfortunately changing the nat statement didn't work. I thank you for your help.
I had made the change from my static nat to nat (dmz 101 0 0. But it got worse,No I'm back to getting reject by implicit deny. before I replace nat of dmz at the very least I was seeing tcp syn timeouts .
I just wanted to get the outside interface to allow web.
mdhaka Tue, 12/04/2007 - 16:41
Inspite of using interface ip address,can we try to use another public ip?
If not,try commands-
access-list DMZ_access_in extended permit tcp any interface outside eq www
static (DMZ,outside) tcp interface 80 192.168.2.249 80
mdhaka Tue, 12/04/2007 - 16:43
bmarlin Wed, 12/05/2007 - 07:22
Hello and thanks for suggestions,
Unfortunately nothing suggested has worked properly.I have reached a point where I may just try a rebuilt of the system. I will keep you all informed.
bmarlin Wed, 12/05/2007 - 09:16
Hello
I have attempted a rebuilt ?fw and here is the log I now get when trying to get to DMZ SERVER,
connection denied from 142.165.31.5/1248 to 69.11.97.143/80 flags SYN on interface Outside.
Thanks again for the help
Jon Marshall Wed, 12/05/2007 - 09:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Can you post your updated config
Jon
bmarlin Wed, 12/05/2007 - 10:04
here are my 2 latest syslog events when trying to connect to dmz server
302013 142.165.31.5 69.11.97.143 Built inbound TCP connection 6059 for Outside:142.165.31.5/1541 (142.165.31.5/1541) to DMZ:69.11.97.143/80 (69.11.97.143/80)
6 Dec 05 2007 10:25:26 110003 Routing failed to locate next hop for TCP from Outside:142.165.31.5/1541 to DMZ:69.11.97.143/80.
Jon Marshall Wed, 12/05/2007 - 10:23
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Change
"static (DMZ,Outside) interface 69.11.97.143 netmask 255.255.255.255"
to
static (DMZ,Outside) interface 192.168.2.x netmask 255.255.255.255
where 192.168.2.x is the address of the web server.
Jon
bmarlin Wed, 12/05/2007 - 14:19
Hi Jon
have made change still not working.
bmarlin Thu, 12/06/2007 - 06:59
Found problem, Not firewall routing is suspect
Thanks everyone for your help.
