Impossible to assign interfaces to vlans in cisco2801
Dec 4th, 2007
i want to use the wic-4esw module on a cisco 2801.
Each of the ports must be assigned 1 vlan.
I've already achived to get the output below, but still the protocol is down for each port:
FastEthernet0/0.1 is up, line protocol is down
Hardware is Gt96k FE, address is 0017.590a.c122 (bia 0017.590a.c122)
Internet address is
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 2.
My cisco 2801 , doesnt accept the command :
interface vlan.
What to do?
Pls help me,regards
show vlan-switch
Hi, your 2801 may need you to use the vlan database command to configuer vlan's. have a look below.
VLAN Configuration Mode
You can use the VLAN configuration commands to create or modify VLAN parameters for VLAN IDs 1 to 1005.
Enter the vlan database privileged EXEC command to access VLAN configuration mode:
Switch# vlan database
Switch(vlan)# vlan xxx name yyy
Switch(vlan)# exit
when using the vlan database you must type exit command to apply your changes.
x will be the vlan ID number and y will be the vlan name.
