How to allow MS VPN outbound on PIX 501
Dec 4th, 2007
I'm sure this is standard stuff, but I cant figure it out. I want to allow MS VPN connections initiated from inside to get out a PIX 501. Any help?
JORGE RODRIGUEZ Tue, 12/04/2007 - 12:07
you need to allow through the ipsec vpn ports in firewall, udp 500 udp 4500 and protocol esp.
access-list inside permit udp any any eq 500
access-list inside permit udp any any eq 4500
access-list inside permit esp any any
access-group inside in interface inside
rate any helpful post if it does!
ciscospaz Tue, 12/04/2007 - 12:14
Thanks Jorge,
Does this apply if it's only a PPTP connection?
JORGE RODRIGUEZ Tue, 12/04/2007 - 12:37
This is only for Cisco VPN client, for pptp use the info and link posted by others in this thread.
kevin.jones1 Tue, 12/04/2007 - 12:12
1) use Pix OS code 6.3(5),
2) fixup pptp protocol 1723
It will work after that.
ciscospaz Tue, 12/04/2007 - 12:42
That did the trick, thanks.
Would I still need these ACL statements I tried earlier?
access-list outside_access_in permit gre any any
access-list outside_access_in permit tcp any any eq pptp
Thanks again,
kevin.jones1 Tue, 12/04/2007 - 16:47
you do NOT need to allow anything on the
outside interface. In fact you can even do
access-list ccie_security deny ip any any log
access-group ccie_security in interface outside
your pptp still works after that because
the connection is initiated from the inside
ciscospaz Tue, 12/04/2007 - 17:16
Didn't think so, but I was grasping at anything.
Thanks for helping.
