Phones show 2 time formats; how do we change?
Answered Question
Dec 4th, 2007
I have 7941's that show the time in 12-hour format and other ones that show in 24-hour format. Can I go into my Date/Time group and select 12-hour format, update and then will the pones all show AM & PM format when the time of day rolls around?
Correct Answer by jstemke about 8 years 10 months ago
Yes, set the format in the Date/Time Group and then check to see that your Device Pools are using the correct Date/Time Group.
Overall Rating: 5 (1 ratings)
Correct Answer
jstemke Tue, 12/04/2007 - 12:19
rob.huffman Tue, 12/04/2007 - 12:24
Hi John,
Hope things are good with you! If you are seeing this problem we know that you must have at least two Date/Time Groups configured. You will need to determine which Group(s) is/are using the 24-Hour format and apply these changes;
Updating a Date/Time Group
This section describes how to update a date/time group.
Step 1 Find the date/time group by using the procedure in the "Finding a Date/Time Group" section.
Step 2 From the list of matching records, choose the date/time group that you want to update.
Step 3 Update the appropriate settings as described below
Group Name
Enter the name that you want to assign to the new date/time group.
Time Zone
Choose the time zone for the group that you are adding.
The default setting for new Cisco CallManager installations equals (GMT) Monrovia, Casablanca.
If you configured the "local time zone of Cisco CallManager" option with a previous Cisco CallManager release, the Cisco CallManager 4.1 database determines the time zone for the publisher database server and displays that time zone.
Choose the separator character to use between the date fields.
Date Format
Choose the date format for the date that displays on the Cisco IP Phones.
***Time Format
Choose 12-hour or 24-hour time.
Step 4 Click Update to save the changes in the database.
Step 5 To apply the changes, press the Reset Devices button.
Hope this helps!
j.mccartney Tue, 12/04/2007 - 12:31
Hey Rob,
Thanks for the information. I looked and we only have one Date/Time group. After further review it looks like this was a lingering issue from when we did some DST patches and the phones that showed incorrect time were ones where people had not logged out until now. When they logged back in the correct time showed up. I did also change the time format from 24-hour to 12-hour.
Thanks again as usual.
