mchandak Tue, 12/04/2007 - 13:55
  • Gold, 750 points or more
Hi Justin,
Yes, Exchange 2003 is supported with Exchange 2003. Check the following link for information about supported softwares with Unity 4.0(x)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/41/requirements/40_41cusysreq.html
For requirement and support information about other versions of Unity, you can access the guides at:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_installation_guides_list.html
And for all other types of Compatibility Matrix with Unity, you can check:
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_device_support_tables_list.html
Hope this helps
