Top Usage Status
Dec 4th, 2007
Hello...
I have a PIX Firewall 515E with version 8.0.2 and ASDM 6.0.2 and I have a problem.
I enabled the Top Usage Status (Top 10 Services / Top 10 Sources / Top 10 Destinations) in the 'Firewall Dashboard' menu and now the Memory Utilization is very high.
I do not know how to stop these features.
Could you help me?
Thanks...
husycisco Wed, 12/05/2007 - 12:20
  • Gold, 750 points or more
try the following command in CLI
no logging buffered
r.nockowitz Fri, 10/10/2008 - 15:34
you need to disable in the pix command line:
no threat-detection statistics protocol
that should reduce the RAM usage..
if that doesn't reduce it enough for you, then type:
sho run | inc threat
the output will show you all of the "threat-detection" commands.. disable one at a time..
but think that the "threat-detection statistics protocol" is the memory hog
Rob Nockowitz
CCIE #15410
robertson.michael Sat, 10/11/2008 - 07:59
  • Silver, 250 points or more
Also, there are a few memory leak bugs filed for 8.0(2) and 8.0(3). If you want to re-enable threat-detection in the future, I would recommend an upgrade first so you can get the fixes for the memory leaks.
-Mike
