rommon 1 >
Richard Burts Tue, 12/04/2007 - 14:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Vlad
Even if the router is not configured yet it is not normal for it to boot into rommon. It might be helpful to figure why it is doing this. Some reasons that it might do this include:
- a setting of the config register instructs the router to boot into rommon
- the image file in flash is corrupt
- there is no image file in flash
Could you boot the router, capture and post the console output while it is booting? This would give us some insight into why it is booting into rommon.
Rick
Rick,
thank you for quick response. Here is the the console ouput:
System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
Initializing memory for ECC
c2821 processor with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
device does not contain a valid FS
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
rommon 1 >
Collin Clark Tue, 12/04/2007 - 14:30
  • Purple, 4500 points or more
Here's a link with step-by-step instructions.
http://cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00801fc986.shtml
This should help when configuring in rommon too.
rommon 1 >IP_ADDRESS=10.1.2.55
rommon 2 >IP_SUBNET_MASK=255.255.255.0
rommon 3 >DEFAULT_GATEWAY=10.1.2.254
rommon 4 >TFTP_SERVER=10.1.2.7
rommon 5 >TFTP_FILE=c870-advipservicesk9-mz.124-15.T1.bin
rommon 6 >tftpdnld
All of the above are required!
HTH and please rate.
Richard Burts Tue, 12/04/2007 - 14:45
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vlad
Thanks for the additional information. It is quite helpful and clearly shows the reason that the router is booting into rommon. There is a problem with the flash and the router can not find any image file to boot. Does this router have its flash on a compact flash? If so can you verify that there is a card in the compact flash slot? If there is a card can you remove it, replace it (reseat it), and try the boot again?
The information provided by Collin about how to do tftpdnld is very good and may be needed after we resolve the issue about the problem in flash. But it will not work until the issue about flash is resolved.
Rick
Rick and Collin,
I ran tftpdnld and here is the output. Should I proceed and press "Y"?
IP_ADDRESS: 10.1.2.55
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 10.1.2.254
TFTP_SERVER: 10.1.2.7
TFTP_FILE: C870-advipservicesk9-mz.124-15.T1.bin
TFTP_VERBOSE: Progress
TFTP_RETRY_COUNT: 18
TFTP_TIMEOUT: 7200
TFTP_CHECKSUM: Yes
TFTP_MACADDR: 00:15:63:8f:4a:c0
GE_PORT: Gigabit Ethernet 0
GE_SPEED_MODE: Auto
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]:
Collin Clark Wed, 12/05/2007 - 08:22
Is this the actual input? If so you'll need to enter your values such as your TFTP Server, the correct IOS image, etc.
Richard Burts Wed, 12/05/2007 - 08:26
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vlad
NO - do not press Y yet. There are several problems that must be resolved before you do this.
First problem: have you resolved the problem with flash on the router? tftpdnld will try to copy the image to flash and if there is still a problem with flash (as there was in the prior attempt to boot) then tftpdnld will fail.
Second problem: the values in the instructions that Collin provided were example values (IP address, subnet mask, default gateway, tftp server, tftp file) and you need to put in values that are correct for your environment.
when you get both of these resolved then you can try tftpdnld.
Rick
Richard Burts Wed, 12/05/2007 - 08:59
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vlad
It is good to know that you have reseated the card. I had hoped that this might fix the problem (I have seen several routers where the flash card had become not well seated and the router would not boot with similar symptoms and the problem was fixed when the card was reseated).
Now that the card has been seated are you still getting exactly the same messages when your attempt to boot:
With the card reseated it would be ok to try tftpdnld and see what happens. Do be sure to change the values specified for tftpdnld to what is right for your network and router.
I am a bit concerned that there is still some problem with the flash card and that the tftpdnld may fail again. But we will not know until you try it.
Rick
glen.grant Wed, 12/05/2007 - 09:01
Is this a cisco flashcard or did someone try to use a generic flash in it ?
Richard Burts Wed, 12/05/2007 - 09:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vlad
Is this flash card original to the 2821? Or was it perhaps transferred to the 2821 from some other Cisco router? Is transferred, then from what platform did it originate?
Rick
Richard Burts Wed, 12/05/2007 - 13:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vlad
NO do not download c870-advipservicesk9-mz.124-15.T1.bin to the TFTP server. That image is for the 870 series of routers. You need an image for 2800 series of router.
In your original post you say that the 2821 is not configured yet. Perhaps it would help us if you would tell us a bit about this router. Have you had it for a while or is it recently acquired? If it is recently acquired from where did you acquire it?
You get images for download from the Cisco web site (which will require a CCO ID with authorized privileges to download software). You would be able to identify the particular version that would fit your router on the Cisco web site.
Rick
Rick,
I downloaded IOS 12.4.17a from cisco website and ran tftpdnld utility. Here is input and output:
rommon 1 > IP_ADDRESS=216.214.47.30
rommon 2 > IP_SUBNET_MASK=255.255.255.0
rommon 3 > DEFAULT_GATEWAY=216.214.128.134
rommon 4 > TFTP_SERVER=10.10.10.5
rommon 5 > TFTP_FILE=c2800nm-spservicesk9-mz.124-17a.bin
rommon 6 > tftpdnld
IP_ADDRESS: 216.214.47.30
DEFAULT_GATEWAY: 216.214.128.134
TFTP_SERVER: 10.10.10.5
TFTP_FILE: c2800nm-spservicesk9-mz.124-17a.bin
TFTP_TIMEOUT: 7200
TFTP_CHECKSUM: Yes
GE_SPEED_MODE: Auto
Do you wish to continue? y/n: [n]: y
ARP: address resolution for 216.214.128.134 timed out.
ARP failed with failure code 1. TFTP transfer aborted.
TFTP: Operation terminated prematurely.
rommon 7 >
Richard Burts Wed, 12/05/2007 - 19:44
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vlad
There are several things that appear to be inconsistent in the way that you set up tftpdnld and perhaps these caused the problem when you attempted to run the utility.
You set the address to use on the router as 216.214.47.30 with a mask of 255.255.255.0. Normally I would expect the default gateway to be an address in the same subnet, but you configured the gateway as 216.214.128.134. Note in the error messages that the router is attempting to ARP for the default gateway address but gets no response. The failure to receive an ARP response is what causes the TFTP to abort. I suggest that you try it again and this time put a gateway address that is a layer 3 routing device that is in the same subnet.
The default gateway would not matter if the TFTP server was in the same subnet as the router doing tftpdnld. But you configured the TFTP server as 10.10.10.5. So to get to this address the router does need its default gateway.
I would suggest that you try the tftpdnld again. This time think through the various devices that are involved (router, tftp server, and possibly default gateway) and the addresses used on each of these devices.
Give it a try and let us know if it works.
Rick
Rick,
I changed an address on TFTP server. It is 216.214.47.112 now.
The router's ip I'm assuming will be 216.214.47.30
216.214.47.1 is the ip address of the router where 2821 connects to.
Also TFTP server is the same PC that I'm connecting to the router's console.
Here is input and output of HyperTerminal:
rommon 4 > TFTP_SERVER=216.214.47.112
rommon 6 > tftpdnld
TFTP_SERVER: 216.214.47.112
TFTP_TIMEOUT: 7200
TFTP_CHECKSUM: Yes
GE_SPEED_MODE: Auto
ARP: address resolution for 216.214.47.112 timed out.
rommon 7 >
Thank you.
ccbootcamp Wed, 12/05/2007 - 20:32
  • Gold, 750 points or more
Vlad,
Get a USB CF card reader. Copy the file from your PC over onto the CF card using your PC. It's a very easy way to do it. I've loaded hundreds of CF cards for 2800 series routers this way. It will make your life VERY easy.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
ccbootcamp Thu, 12/06/2007 - 10:41
Go buy yourself a CF reader, it will do you good in the long run. It's a $15 investment well worth it. Please rate my posts, I appreciate it. :)
-brad
