VPN Client v5.0.01.0600 - Vista and code 412
Dec 4th, 2007
Does anyone know how to resolve code 412 on WinVista?
See log below:
Thanks, Hans
Cisco Systems VPN Client Version 5.0.01.0600
Copyright (C) 1998-2007 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 6.0.6000
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1 10:33:06.196 12/05/07 Sev=Info/6 CERT/0x63600026
Attempting to find a Certificate using Serial Hash.
2 10:33:06.197 12/05/07 Sev=Info/6 CERT/0x63600027
Found a Certificate using Serial Hash.
3 10:33:06.199 12/05/07 Sev=Info/6 GUI/0x63B00011
Reloaded the Certificates in all Certificate Stores successfully.
4 10:33:09.280 12/05/07 Sev=Info/4 CM/0x63100002
Begin connection process
5 10:33:09.406 12/05/07 Sev=Info/4 CM/0x63100004
Establish secure connection
6 10:33:09.406 12/05/07 Sev=Info/4 CM/0x63100024
Attempt connection with server "zeus.petermac.org"
7 10:33:09.609 12/05/07 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 203.4.167.9.
8 10:33:09.798 12/05/07 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 203.4.167.9
9 10:33:09.801 12/05/07 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
10 10:33:09.801 12/05/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
11 10:33:09.801 12/05/07 Sev=Info/4 IPSEC/0x6370000D
Key(s) deleted by Interface (169.254.55.225)
12 10:33:14.826 12/05/07 Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
13 10:33:14.826 12/05/07 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (Retransmission) to 203.4.167.9
14 10:33:19.896 12/05/07 Sev=Info/4 IKE/0x63000021
15 10:33:19.896 12/05/07 Sev=Info/4 IKE/0x63000013
16 10:33:24.966 12/05/07 Sev=Info/4 IKE/0x63000021
17 10:33:24.966 12/05/07 Sev=Info/4 IKE/0x63000013
18 10:33:30.036 12/05/07 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=F1F24D1B25D17EF7 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
19 10:33:30.550 12/05/07 Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=F1F24D1B25D17EF7 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
20 10:33:30.550 12/05/07 Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "zeus.petermac.org" because of "DEL_REASON_PEER_NOT_RESPONDING"
21 10:33:30.550 12/05/07 Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
22 10:33:30.552 12/05/07 Sev=Info/6 CM/0x63100046
Set tunnel established flag in registry to 0.
23 10:33:30.552 12/05/07 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
24 10:33:31.058 12/05/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
25 10:33:31.058 12/05/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
26 10:33:31.058 12/05/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
27 10:33:31.058 12/05/07 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
hansfeitz Tue, 12/04/2007 - 20:15
Hi Jorge,
Thank you very much, adding "UseLegacyIKEPort=1" to the pcf file was the only option I had and that worked perfectly.
Cheers, Hans
