VPN Client w/ Vista problem
Dec 4th, 2007
Running Vista Home Premium. Installed the latest VPN Client (Vista compatible), version 5.0.02.0090. After rebooting my PC and trying to connect, I get a blue screen. The blue screen doesn't tell me much, but I continue to recieve it every time I try connecting through the client. I have tried clean installs with no luck. I am a local admin of the PC. Any ideas? Tried checking log files and event viewer but it doesn't tell me anything. No log files exist within Prog Files\Cisco\VPN Client\Logs. Thanks
-Ryan
ivillegas Tue, 12/11/2007 - 14:05
There is a bug CSCsd03468 regarding getting a blue screen after installing VPN client software. Check if there are other conflicting virus softwares installed before installing the VPN client.
laxcis Sat, 12/22/2007 - 08:24
Found a work around on this. I could actually install the software fine, it was just when I opened a vpn connection that I would receive the blue screen. By disabling my virus scan suite (trend micro) before starting my vpn connection, I am then able to open a connection just fine without any blue screens.
