SSL VPN: Anyconnect client fails to install
Dec 4th, 2007
I have a 2801 with 12.4(15)T1 advanced IP servcies image installed.
I can download the Anyconnect client from the WebVPN portal however the isntall fails. The debug from the 2801 gives me the following:
001211: *Dec 4 07:31:26.899 UTC: WV-TUNL: Tunnel CSTP Version recv use 1
001212: *Dec 4 07:31:26.899 UTC: WV-TUNL: Allocating tunl_info
001213: *Dec 4 07:31:26.899 UTC: WV-TUNL: Allocating stc_config
001214: *Dec 4 07:31:26.899 UTC: WV-TUNL: Allocating address from local pool
001215: *Dec 4 07:31:26.899 UTC: WV-TUNL: Cannot find IDB for IP address in table 0
001216: *Dec 4 07:31:26.899 UTC: WV-TUNL: Returning address to pool
001217: *Dec 4 07:31:26.899 UTC: WV-TUNL: Failed to config IP addr ( to VRF Table (0)
001218: *Dec 4 07:31:26.899 UTC: HTTP/1.1 401 Unauthorized
Can anyone shed some insight into what this debug means?
It's mentioning VRF but I do not have VRF configured and I'm strugglign to understand why I'd need it.
Scott Cannon Tue, 12/04/2007 - 22:16
Hi All,
Further to this, I've attempted circumventing this issue by downloading the Anyconnect client and installing it manually on the remote machine.
Now when the machine attempts a conenction (and fails) I see the following debug on the router:
000090: *Dec 5 06:58:17.067 UTC: %SSLVPN-5-HTTP_REQUEST_NOT_AUTHORIZED: vw_ctx: default_context vw_gw: WEBVPNGATE remot
e_ip: status: HTTP request without login cookie resource: /
Now what the heck is that telling me? I thought the authentication cookies were only used when authenticated via the webportal (ie. clientless mode)?
