Port forwarding from inside to outside
Dec 4th, 2007
I have a device(s) on the outside of my network that I have to access from a specific ip:port on my network.
inside ip:
firewall ip inside
firewall outside:
i have to access device from
device ip is public address
I am probably trying to make this to hard and confusing myself. Any help would be appreciated.
Running Pix535 v7.2(2)
srue Tue, 12/04/2007 - 19:52
static (inside,outside)
static (inside,outside) tcp 9000 9000
this assumes you're using TCP, not udp. change appropriately if you need to.
the first statement will translate port for port. ie, inside port 9000 is 'translated' to outside port 9000.
jkassel Tue, 12/04/2007 - 20:09
that is what i was thinking but my problem is that the app used to access this does not use a static port. could i use a route-map on a inside router before the firewall to fix this?
