how to sync AP names from WLC to WCS
dbentley Wed, 12/05/2007 - 07:25
In 4.2.61 you go under the controller tab on the WCS and select the controllers that you would like to update. Select the drop down for 'Refresh config from controller' Select then select the delete tab on the following screen. This will take all the information from the WLC and move it to the WCS and delete any outdated information on the WCS. Hope this helps.
