2811 Router cannot load IOS from Flash
kelloggs4life
I have a 2811 router that was recently uploaded with a new IOS. The router was however unable to load the new IOS as well as the previous one.
All efforts to lead try and load from the flash has failed. Router just keeps giving "cannot load flash" error and defaults to rommon prompt.
Any ideas please?
Hi Femi ,
Follow the below steps which helps you to come out the rommon mode...
If your router keeps entering the ROMmon mode each time the system is restarted, it is probably due to the setting of the configuration register. To verify the configured value of the configuration register, use the confreg command as shown below:
rommon 2 > confreg
Configuration Summary
enabled are:
load rom after netboot fails
console baud: 9600
boot: the ROM Monitor
do you wish to change the configuration? y/n [n]: As indicated by the output of the confreg command above, the configuration register is set to a value that forces the router to go into the ROMmon mode each time it is reloaded or power-cycled. To make the router boot automatically from a default Cisco IOS software image, change the configuration register value as shown below:
rommon 2 > confreg
enabled are:
console baud: 9600
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
disable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
enable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]:
change the boot characteristics? y/n [n]: y
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2-15 = boot system
[0]: 2
enabled are:
console baud: 9600
boot: image specified by the boot system commands
or default to: cisco2-C2600
do you wish to change the configuration? y/n [n]: n
You must reset or power cycle for new config to take effect
By doing this, you have changed the configuration register to a value that makes it look for a valid Cisco IOS software image on startup and boot from the same. The router must now be reset.
rommon 3 > reset
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
The router should now reload with a valid Cisco IOS software image.
Look for a Valid Image in Flash
If the configuration register value is set to make the system boot automatically from a default Cisco IOS software image, and if no break signal is sent during start up, the router should boot normally. However, if the router still enters the ROMmon mode, it is probably because the device is unable to locate a valid Cisco IOS software image.
The first thing you need to do then is to look for a valid Cisco IOS software image. To do this, issue the dir command for each available device, and look for a valid Cisco IOS software image. For example, to look for the IOS in the Flash, use the command shown below.
rommon 1 > dir flash:
File size Checksum File name
5358032 bytes (0x51c1d0) 0x7b16 c2600-i-mz.122-10b.bin
rommon 2 >
Note that if the router returns the "bad device name" message, the device specified probably does not exist. The output above indicates that a valid image is indeed present in the Flash. Try to boot from that image using the boot command.
rommon 2 > boot flash:c2600-i-mz.122-10b.bin
program load complete, entry point: 0x80008000, size: 0x51c0dc
Self decompressing the image : #################################################
The router should now boot with the Cisco IOS software image specified in the boot command. However, there are times when a valid image does not exist on any of the devices or the image on the Flash might be corrupted. In these cases, a valid image has to be downloaded using Trivial File Transfer Protocol (TFTP) or by using the Xmodem procedure. Both these procedures can be carried out from the ROMmon mode.
satish
9 Replies 9
lgijssel
Level 9
Level 9
Please upload the console output from the failed boot sequence. The part of the config that relates to booting and a dir: of your flash would be nice to have a look at also.
Leo
Hi Leo,
Below is the console output:
rommon 2 > reset
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
loadprog: error - on read during ELF program load
requested 26002760 (0x18cc548) bytes, got 22314364 (0x1547d7c)
boot: cannot load "flash:"
rommon 1 >
how do i display the dir of the flash from rommon?
Femi
Hi Leo,
Here is the output of the dir of the flash:
rommon 16 > dir flash:
Directory of flash:
2 22337524 -rw- c2800nm-spservicesk9-mz.123-8.T10.bin
3642 1823 -rw- sdmconfig-2811.cfg
3643 4734464 -rw- sdm.tar
4799 833024 -rw- es.tar
5003 1052160 -rw- common.tar
5260 1038 -rw- home.shtml
5261 102400 -rw- home.tar
5286 491213 -rw- 128MB.sdf
5406 1684577 -rw- securedesktop-ios-3.1.1.27-k9.pkg
5818 398305 -rw- sslclient-win-1.1.0.154.pkg
5916 2736 -rw- SDM_Backup
8829 14906116 -rw- c2800nm-ipbase-mz.124-3g.bin
Femi
Hi Femi ,
rommon 2 > confreg
enabled are:
console baud: 9600
rommon 2 > confreg
enabled are:
console baud: 9600
enter to boot:
0 = ROM Monitor
2-15 = boot system
[0]: 2
enabled are:
console baud: 9600
rommon 3 > reset
rommon 2 >
satish
Hello Satish,
Thanks a lot for your post. It was quite helpful. I have been able to resolve the issue by simply booting the router from the good IOS from the rommon> mode with the following command just as you stated above...
rommon 2> boot flash:****
And thanks to all who dropped one suggestion or the other. You all have been quite helpful.
Cheers,
Femi
bvsnarayana03
Level 5
Level 5
Not sure if you have both images in flash & cant find one due to absence of boot command in configuration or probably the old ios is erased & new ios didnt load.
Try this. from rommon set the confreg to "0x2101" & reload. Now use the boot command to specify the image to be loaded while powercycle.
If this works, well & good otherwise you may have to load the ios once again.
Pls refer this link:
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a0080110ed1.shtml
That's about what I wanted to advise you as well. The spservices image is the one that the router tries to load but it looks corrupted with an invalid length.
That is probably why the router cannot find the ipbase image that is also on flash.
It looks as if there is little free room on your flash anyway. In that case, you will need to delete one image to make all of this fit.
regards,
Leo
Delete the bad IPServices flash image from flash. Boot the router. After the router boots to the ipservices image, delete the ipservices image. then go ahead and transfer over the new image.
or:
use a CF card reader, connect the CF card reader to your pc. delete both images. copy over a new spservices image. stick the cf card back in the router and go.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
