642-453
Dec 4th, 2007
hallo to everyone...... i wanna know if somebody has gone for 642-453(Gateway-Gatekeeper) exam. If yes than watz the difference between 642-452(expired) and 642-453 ...plz reply me
erikjustinlee Wed, 12/05/2007 - 06:00
I took the 642-453 about 2 months ago. It wasn't as bad as I thought it was going to be. I just used the outline on the cisco website and some docs off of the Univercd.
Good Luck. :)
mabrook110 Wed, 12/05/2007 - 10:16
thanx for reply ...but i wanna know if there is a difference between 642-452 and 642-453 Ive the study guide but i'm not sure for the difference....
erikjustinlee Wed, 12/05/2007 - 11:50
From what I saw no. The difference was in the syntax of the commands and the different versions of the IOS that you have to support. I think if you know the matterial for the 452 you should have no problem with the 453.
mabrook110 Wed, 12/05/2007 - 23:15
thanx once again!!!!! have you refered to any question-answers from actual tests or any other brain dumps for 642-452????? are they useful?
erikjustinlee Thu, 12/06/2007 - 05:33
Well if you use the practice questions to test if you know the content than they are good. The content is the same. The questions will be worded different. You probably want to get the 453 ones though.
dbenattou Fri, 01/18/2008 - 17:14
hello,
can you post me the book, i have not found it .
Thanks at advance.
erikjustinlee Wed, 01/23/2008 - 07:28
I just went to cisco.com/univercd and read through the gatekeeper and the gateway docs that they had on there.
