Disabling EIGRP but keeping routes
Dec 5th, 2007
Just curious if i turn off EIGRP on my routers by using the no ip eigrp command will the routes which were discovered via the EIGRP protocol remain in the routing table. Or will i have to add static routes for them?
Thanks in advance.
Jon Marshall Wed, 12/05/2007 - 01:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Matthew
If you turn off eigrp on your router ie.
router(config)# no router eigrp "as no"
then all the EIGRP learned routes will be removed immediately from the routing table.
Jon
vinil.sudhir Thu, 12/06/2007 - 18:54
U might wanna add all the static routes first and the disable eigrp.
