I found a route-map command in the ASA v8 command refernce, it has the same structure as the route-map in router. does this command function like the router one or it has different function.
Route maps are used when redistributing routes into an OSPF, RIP, or EIGRP routing process. They are also used when generating a default route into an OSPF routing process. A route map defines which of the routes from the specified routing protocol are allowed to be redistributed into the target routing process.
