MAC-Learning in EoMPLS
attrgautam
Level 5
Level 5
I was wondering if in a EWS circuit, does the MPLS PE Router learn the MAC-Address or is it dependent on the way the Circuit is configured i.e. Type-4 and Type-5 or Sub-interface based or SVI based.
Is there any way this MAC-learning can be disabled...Also, if MAC-learning is enabled does this have a direct impact on the number of MAC-addresses I can learn in any other service like VPLS or ERS etc....
oldcreek12
PE should not and does not need to learn MAC-address for EoMPLS, this is irrelevant of circuit type.
Cat6K has mac-limiting feature which you can limit the number of MACs can be learned on per-vlan bases.
MAC learning is only required if you need local switching, which requires a SIP or an ES20 card.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
