12-05-2007 03:47 AM - edited 03-05-2019 07:50 PM
I saw below message in my 3750 CISCO device :
00:01:02: %PM-4-ERR_DISABLE: gbic-invalid error detected on Gi1/0/1, putting Gi1/0/1 in err-disable state
How to debug this ? How can I make it to connected state ?
Vijaybabu
12-05-2007 03:52 AM
There is appearently a problem with the SFP module in this slot.
Issueing a shut - no shut on the interface will re-enable it but if the problem is persistent it will re-appear very shortly.
Replacing the SFP would be a good start.
Have you perhaps been trying to use the CAB-SFP-50cm in the 3750? These will fit but they only operate in the 3560 series.
regards,
Leo
12-05-2007 04:04 AM
can you do show errdisable recovery and copy that
12-05-2007 04:26 AM
After I changed the SFP, it showing as below :
00:35:51: %GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port 65538 has bad crc
Cisco#sh errdisable recovery
ErrDisable Reason Timer Status
udld Disabled
bpduguard Disabled
security-violatio Disabled
channel-misconfig Disabled
vmps Disabled
pagp-flap Disabled
dtp-flap Disabled
link-flap Disabled
gbic-invalid Enabled
l2ptguard Disabled
psecure-violation Disabled
dhcp-rate-limit Disabled
unicast-flood Disabled
loopback Disabled
Timer interval: 400 seconds
Interfaces that will be enabled at the next timeout:
Cisco#
Vijaybabu
12-05-2007 04:40 AM
What kind of SFP is this (Copper/Fiber)? Can you give us a part description such as GLC-SX-MM for the 1000Base SX Multimode SFP?
The errors that you observe may be related to the type of media that is used:
Bad patch cable, bad fiber cable, too little optical output from the other side, ..
regards,
Leo
12-05-2007 05:02 AM
Its not CISCO SFP.
Anyway, I shifted to use fa port.
Thanks all for your support.
Vijaybabu
