Cisco Messaging Interface down
Answered Question
Hi all,
I'm having an issue on a CUCM machine running 6.0.1.2112-1. If I run the RTMT I get to see numerous of alerts saying:
'Service status is DOWN.
Cisco Messaging Interface...'
The alert keeps popping up every 30 seconds.
Can anyone tell me what the cause of this alert could be, and how it can be solved?
With kind regards,
Paul van den IJssel
Digacom, The Netherlands
Correct Answer by ouhakheme about 9 years 3 months ago
Hello Paul --
I assume that you are using Cisco Unity/Unity Connection/Unity Express for the voicemail platform. If so, you will not need the Cisco Messaging Interface service and you can deactivate it from the serviceability pages. The service is only needed for external voicemail systems that are not Cisco.
Please let me know if you have any other questions. I hope this helps. Please rate helpful posts.
Ohamien
Overall Rating: 5 (2 ratings)
Correct Answer
ouhakheme Wed, 12/05/2007 - 06:10
Hello Paul --
Ohamien
Holly Miller Mon, 06/16/2014 - 14:50
I have this error in RTMT as well.  But Cisco Messaging Interface is definitely disabled on the Service Activation page.  Any idea how I can prevent this error?
