How to delete empty failed entries from Archive Mgmt
Dec 5th, 2007
I'm having some failed entries w/o IP addresses in Archive mgmt.
Config Mgmt-Archive Mgmt---Configuration Archival Summary:
Successfull: 10
Failed:5
Partial
Total:15
Is there any to way to clear/delete them...
Ex:
1. (Device Name-Empty here) PRIMARY RUNNING Oct 07 2007 14:10:43 Failed to fetch config using RCP.Connection refused: connect Verify RCP is enabled or not.
Joe Clarke Wed, 12/05/2007 - 09:00
There is no way to forcibly clear these entries without going into the database (or reinitializing the database). Though while these failed entries may look bad, they should not cause any problems with the application.
aijaz802 Sun, 01/13/2008 - 03:28
any software to open the database file and delete these entries!!!. By doing reinitializing the db, will I'm lose any archived data.(configs/images).
Show me a way to remove these entries...
Thanks...
Joe Clarke Sun, 01/13/2008 - 11:07
There is no tool designed to purge this table in the database. I suggest you open a TAC service request, and discuss what you are seeing with them.
