Logo IP telephone
Answered Question
Dec 5th, 2007
How I can change the Cisco logo, in the call manager express 4.2?
Correct Answer by Rob Huffman about 9 years 5 months ago
Hi Ricardo,
Sorry about that :) Maybe this will be more helpful.
CallManager Express: Create a Customized Background Image for the 7970 IP Phone
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a008062495a.shtml
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Rob Huffman Wed, 12/05/2007 - 06:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ricardo,
Have you looked into using this CME Feature?
System Message Display
The System Message Display feature allows you to specify a custom text or display message to appear in the lower part of the display window on display-capable IP phones. If you do not set a custom text or display message, the default message "Cisco Unified CME" is displayed.
When you specify a text message, the number of characters that can be displayed is not fixed because IP phones typically use a proportional (as opposed to fixed-width) font. There is room for approximately 30 alphanumeric characters.
The display message is refreshed with a new message after one of the following events occurs:
Busy phone goes back on-hook.
Idle phone receives a keepalive message.
Phone is restarted.
The file-display feature allows you to specify a file to display on display-capable IP phones when they are not in use. You can use this feature to provide the phone display with a system message that is refreshed at configurable intervals, similar to the way that the text message feature provides a message.
The difference between the two is that the system text message feature displays a single line of text at the bottom of the phone display, whereas the ***system display message feature can use the entire display area and contain graphic images.
SCCP: Modifying System Message Display
To modify the system message display on phone screen, perform the following steps.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. system message text-message
5. url idle url idle-timeout seconds
6. end
System File Display: Example
The following example specifies that a file called logo.htm should be displayed on IP phones when they are not in use:
telephony-service
url idle http://www.abcwrecking.com/public/logo.htm idle-timeout 35
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1032353
Hope this helps!
Rob
ricardorojas123 Wed, 12/05/2007 - 07:34
Rob, I need add a picture in the Background Images, from the User Preference/Cack ground Images menu.
Correct Answer
Rob Huffman Wed, 12/05/2007 - 10:22
  • Hall of Fame,
    Founding Member
Hi Ricardo,
Hope this helps!
Rob
omgjames1 Sun, 08/18/2013 - 06:39
How do you do this for Call Manager 8.6.1?
paolo bevilacqua Sun, 08/18/2013 - 09:03
  • Hall of Fame,
    Founding Member
You are responding to a 6 years old thread. Please search the forum and documentation before asking.
Selvarathnam Nadar Mon, 08/19/2013 - 05:46
James,
Just download the List.xml file via the CLI and make the changes as you need.
