How can I configure WPA on an 877w?
Dec 5th, 2007
Hi, I have an 877w configured in VPN mode to my HQ. All works fine. Now I would like to give this remote site wireless access via this 877w. Is there an example config anywhere as i just want to create an SSID and perhaps WPA-PSK authentication?
What I would love to do is authenticate users via a windows RADIUS server at the HQ.
Let me know if you wan the config attached.
ivillegas Wed, 12/12/2007 - 07:17
WPA-PSK configuration is supported on 877w. Here is a sample configuration on CLI
int dot0
encryption mode ciphers tkip
ssid
authentication open
authentication key-management wpa
wpa-psk ascii can be between 8 and 63 ASCI Itext characters
whiteford Wed, 12/12/2007 - 08:03
Thanks, I have added that and can see it, but don't get a DHCP address, how do I auto assign a DHCP address to the wireless users?
whiteford Wed, 12/12/2007 - 22:55
Hi, I'm not sure I understand, do you have an example? I have added the above example and my laptop sees the wireless network when I search, I put in the pre-shared key and authentcate, but it fails on assigning and IP.
I have a lan dhcp scope and a VLAN 1 which is my local router IP.
Let me know if you want the config uploaded.
edliu Sat, 01/19/2008 - 19:37
You must briging the Dot11Radio0 and Fe0.
Then let you lan dhcp server to assign IP adress.
Config example:
bridge-group 1
interface Dot11Radio0
bridge-group 1
int Fe0
bridge-group 1
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
