Internet Script Editor
Answered Question
Dec 5th, 2007
Can anyone point me in the direction of the proper pdf file that will help me a little more in the workings of the ISE?
I'm sure there's one out there somewhere :)
I need to know the requirements for the ISE. I imagine that it isn't more than IE6 but I need to know if it works on IE5.5 and IE7 and was hoping to find a doc that stated all this.
Thanks !
Correct Answer by sanjeev.thallik... about 9 years 1 month ago
Here you go. There will be a section in the document for this. ISE does not run through browser. You need to install the editor on your desktop. It is a client app that uses HTTP/HTTPS to communicate with the distributor.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/ipcc_enterprise/ipccenterprise7_0/user/guide/ipce70sg.pdf
If you cannot locate the doc, search for ICM scripting guide.
Overall Rating: 5 (1 ratings)
Correct Answer
sanjeev.thallik... Wed, 12/05/2007 - 06:03
