Downloadable ACLs on ACS 3.3
Answered Question
Dec 5th, 2007
Hi everyone. I`m having a problem with editing a downloadable ACL on our ACS 3.3.
Whenever I try to edit an ACL in the shared profile component section, I add what I need and then click submit but the changes don't seem to save... As soon as I go to another menu, my changes are gone. Is there something I`m forgetting?
Thanks!
Correct Answer by Jon Marshall about 9 years 2 months ago
After you have edited the ACL and you click "submit" on the page with header
Downloadable IP ACL Content
you must then click "submit" again on the page it takes you back you ie. the one headed
Downloadable IP ACL's
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 12/05/2007 - 06:58
Jon
