What is the difference between the onboard VPN module and adding an AIM module to an 1841 ?
If I do not install an AIM module I get
Cisco 1841 (revision 7.0) with 235520K/26624K bytes of memory.
Processor board ID FTX1127W1AH
2 FastEthernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Modules
If I install the AIM I get the AIM light lit and the following
1 terminal line
2 Virtual Private Network (VPN) Modules
Therefore I am wondering do I even need to add the AIM card to this router or is one built in ?
Darren
