Script Help
Answered Question
Dec 5th, 2007
I need some help with a script for my company. My company will be closing early on Christmas Eve and closed all day on Christmas. I have the Christmas day in my dates.xml and have a subflow calling the Holdiday.aef script. What I am thinking of doing is adding another IF statement and if True do a time of day option that routes to the same holiday prompt as used in the Holiday sublfow. My problem is I don't know how to add If date = 12,24,2007.
Anyone know how to do this or know of a better way?
Thanks!
Correct Answer by BCOLE2007 about 9 years 7 months ago
this should work for the IF,
(dateDay.month == 12) && ( dateDay.dom == 24) && ( dateDay.year ==2007)
dateDay is your date variable, it need to be a Date type variable
Whats wrong with adding 12/24/2007 to your xml file?
Overall Rating: 5 (1 ratings)
Correct Answer
BCOLE2007 Wed, 12/05/2007 - 17:23
  • Bronze, 100 points or more
jjhols Thu, 12/06/2007 - 05:02
Thanks I will test this today.
If I add 12/24 to the XML file it is only for the full day where I need this to enable at 1:00PM on 12/24 and I'll use the XML file for 12/25 which we are closed all day. Please let me know if there is a way I can use the XML file and enable it to work only for a particular day starting a particular time.
Thanks!
andrei.goncalves Mon, 12/10/2007 - 08:25
Hi there.
Try to use the "Time of the Day" Step.
Create a connection with the time of the day you want to check after you're sure that it's the day you want.
Andrei.
