schemberg Fri, 12/14/2007 - 06:46
are you talking about the old (2001 or something) tool? (never worked really) The answer would be: No. Because you have to use HTTPS (SSL).
You can download axltoolkit.zip, it contains a Java toolkit, which allows to access Callmanager database.
ASP Examples and AXL? Which ones?
Axel
