How to Authorize Configuration via ASDM
Dec 5th, 2007
This seems like a very basic question, but I cannot find the answer anywhere.
I am connecting to an ASA 5505 via ASDM, but it tells me that I am only authorized for Home and Monitoring. I want to be authorized for Configuration. How do I do it?
JORGE RODRIGUEZ Wed, 12/05/2007 - 10:57
Hi, you probably do not have admin privilige rights, if using local aaa acounts someone who have full admin rights will need to change the privilege level along with autorization commands allow to your level or make your user account privilege level 15.
In ASDM check under:
device/ administration/users/accounts - as well as device Access/AAA Access
or you could use CLI to change user account privilage level
issue in CLI "show run | username " to show output user accounts and privilige levels, locate your user name.
e.g
config t
to remove user account
ciscoasa#config t
ciscoasa(config)#no username name
and add new with admin privilige
ciscoasa(config)#username name password password privilege 15
Jorge
Pls rate any helpful post
