cisco 878 no carrier detect LED
Dec 5th, 2007
hi,
I have 2 878 routers that will be getting connected via a BT ESP8 4 wire circut, but the carrier detect led will not come on, I have checked with BT and they are saying that they can only see the TX of the routers at both sides.
I have had to use a RG11 to BT plug adaptor as the routers only came with the RJ11-RJ11 patch lead, and the LTU needs to have a BT plug.
Does anybody know what the pinouts are from the routers, as I can't get the link to come up and need to rule out the cabling.
Thanks in advance
Ronnie
ronniepaton Fri, 12/07/2007 - 07:39
Thanks for the response but I have resolved this and it was a cabling pin out problem, I had to make up my own cables.
If anybody is reading this as they have the same fault drop me a mail and I will send the pin outs to you.
