How do I get an ASA-5540 back to default config?
Answered Question
Dec 5th, 2007
Is there an easy way to re-apply the default config that comes with a new ASA-5540? I'd like to have our ASA-5540 be back to its default with 192.168.1.1 on the inside interface and act as a DHCP server so I have connect a PC to it to begin initial configuration using the ASDM.
The ASA-5540 is running on asa723-k8.bin.
Correct Answer by srue about 9 years 2 months ago
configure factory-default
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/c4_72.html#wp2039866
a simple "write erase/reload" would also do the trick.
Overall Rating: 5 (1 ratings)
