Catalyst 2950 problem - switch down
Dec 5th, 2007
I have two 2950 switches connected via fiber and I have set up a cluster. Every day or so I log into the web console to monitor the cluster and the second switch in the cluster shows switch down. I have to connect to the switch via console cable and reload for the switch to comeback online. I upgraded the IOS recently to try to resolve the problem and today I logged into the web console on switch 1 and the second switch in the cluster again shows switch down. I would appreciate any insite into what is wrong with this second switch - maybe possible hardware issue or simply a software problem. Thank you.
srue Wed, 12/05/2007 - 10:38
so when you log in via console connection, the switch is still responsive?
do you have logging turned on?
scotlaclair Wed, 12/05/2007 - 10:44
Yes the switch is responsive only via console cable and I can login via console and use the reload command to resolve the problem. Once the reload occurs, the switch will remain online for at most a couple of days and then I find it un-pingable and using the web console of switch 1 I see that switch 2 shows switch down. I do not have any logging enabled at this time.
sudhakarmorla Wed, 12/05/2007 - 22:58
what are messages displayed when connected to console of switch 2 ?
Like any error or warning messages before going down..
Try enabling logging and pls let us know the messages
scotlaclair Tue, 12/11/2007 - 09:39
Here is the message displayed when the switch crashes:
