Fabric-enabled 10/100/1000 48-port cards for 6509?
Answered Question
Dec 5th, 2007
Does anyone know if there are available fabric-enabled 10/100/1000 48-port cards for 6509's with sup 2's?
Correct Answer by Jon Marshall about 9 years 3 months ago
As Edison says it is fabric-enabled but it does have quite a limitation in that it shares a 1Mb buffer between 8 ports.
Any 67xx module only works with the sup720.
Jon
Correct Answer by Edison Ortiz about 9 years 3 months ago
It is fabric-enabled. It has a dedicated 8Gbps port to the fabric.
Overall Rating: 5 (6 ratings)
Edison Ortiz Wed, 12/05/2007 - 11:17
  • Hall of Fame,
    Founding Member
WS-X6548-GE-TX, however you will also need a SFM module (WS-X6500-SFM2) as the Supervisor II does not have a fabric connection to the chassis.
thomas.reiling Wed, 12/05/2007 - 11:24
Thank you, but this card doesn't seem to be fabric-enabled. I did, however, find the WS-X6748-GE-TX, which looks as if it is fabric-enabled. I wonder if it will work with Sup II's?
Correct Answer
Edison Ortiz Wed, 12/05/2007 - 11:29
  • Hall of Fame,
    Founding Member
thomas.reiling Wed, 12/05/2007 - 13:15
Edison - is this card, WS-X6548-GE-TX, end of life?
And thank you very much for your quick responses.
Correct Answer
Jon Marshall Wed, 12/05/2007 - 11:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
william.briere Wed, 12/05/2007 - 12:17
Does the oversubsription rate on each port (1.2:1) only come into play if the 40 limit is reached?
Jon Marshall Wed, 12/05/2007 - 12:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
William
8Gbps connection to switch fabric.
48 ports.
So each group of 6 ports will get 1Gbps shared between them to the switch fabric. So if you want to avoid oversubscription you can use just 8 ports and each of those ports would get 1Gbps dedicated.
Note that depending on the module the port groups are not necessarily sequential and from memory i can't recall how the port groups are made up on a 6548.
Jon
Jon Marshall Wed, 12/05/2007 - 12:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Thanks Edison, i can never remember these without looking them up :)
Edison Ortiz Wed, 12/05/2007 - 12:32
  • Hall of Fame,
    Founding Member
I used to post information without looking it up, until you correct me on the 6548 being fabric on a previous post :)
Jon Marshall Wed, 12/05/2007 - 12:35
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
william.briere Wed, 12/05/2007 - 12:32
Sorry I should have been more specific...
using a WS-X6748-GE-TX card in a sup-720-3b
Jon Marshall Wed, 12/05/2007 - 12:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
William
In which case you are right about it being 40 ports as the 6748 has 2 x 20Gbps connections to the switch fabric.
I'm going to leave it to Edison for the port groupings :)
Jon
william.briere Wed, 12/05/2007 - 12:40
So can I assume that an individual port will not go into oversubscription if the group it is in is not bandwidth exceeded?
What I mean to ask is if it is a port by port thing. :)
Jon Marshall Wed, 12/05/2007 - 12:41
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Yes, that is a fair assumption.
Jon
Edison Ortiz Wed, 12/05/2007 - 12:42
  • Hall of Fame,
    Founding Member
Correct, and that module also provide 1Mb buffer per port as opposed to 1Mb per 8 ports on the x6548.
william.briere Wed, 12/05/2007 - 12:54
If I have a 6506E and slot 5 has my sup-720-3b should my WS-X6748-GE-TX be in slot 6? Or will I get what we have discussed in slot 1?
Jon Marshall Wed, 12/05/2007 - 12:56
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
You will get the full throughput in any slot in the 6506E as you would with the 6509.
The only chassis you need to be careful with is the 6513 where each slot does not necessarily support 2 x 20Gbps to the switch fabric.
Jon
Edison Ortiz Wed, 12/05/2007 - 17:05
  • Hall of Fame,
    Founding Member
I would leave slot6 for your Secondary Supervisor.
While it should work on slot6, that slot has special power allocated for Supervisor modules.
Choose any slot other than slot5 and slot6, if available.
