problem running a Device Credentials Verification Job
Dec 5th, 2007
Hi. I have this problem:
I want to run a Device Credentials Verification Job. I now have to this but it keep failing with this: Failure Status: CDAJOB009: Either the owner of this job does not exist, or the owner does not have the required permission to run this job.
Im ysing ver. 4.0.6 and all other task runs without any problem.. Is runs in ACS mode. I have also triide to login on af the build in admin account without any help?
David Stanford Wed, 12/05/2007 - 15:46
  • Cisco Employee,
Is the System Identity User was added into the CWAdmin group in ACS? Looks like it may not be configured properly.
Can you make sure that you have customized the roles under Shared Profile Components and given them access to all the options
john.gudmann Wed, 12/05/2007 - 22:50
Hi I have found the reason. The casuser (use for database access on windows) was not a admin user on windows so that it could access the ntfs disk. Just made it at member of admin grup and now it works with all users with the right role on ACS.
