Is the SNMP-server EngineID remote command necessary for CW2000 to poll a device via SNMPv3?
What is the UDP port CW2000 uses by Default 161 ?
Here are my options:
Router(config)#snmp-server engineID remote xx.xxx.xx.xxx ?
WORD engine ID octet string
udp-port The remote notification host's UDP port number
vrf The remote notification host's VPN routing instance
