Switching design
I have some questions about routing and switching design.
I have old Cisco network (Catalyst 4006, ...)
With several end point connected with fiber .
Today i have some network loop (spanning tree is in use).
I have some questions about change in my network.
1) Is it better to change the Catalyst 4006 with 4700 serie, or install 3750 Catalyst switch (using Stackwise techno). ?
2) Is it better to use Etherchannel to secure fiber link rather than spanning tree loop ?
3) To secure my gateway is it possible to use HSRP with 3750. I have one gateway per vlans (10 Vlans).
Thanks for your recommandations
Edison Ortiz Wed, 12/05/2007 - 17:11
  • Hall of Fame,
    Founding Member
1) Since you have a 4006, the 4500 switch seems the most logical path.
Are you planning on upgrading to VoIP ?
If so, the 3750 prices are more competitive. Either choice depends on the switch usage.
4500 Series is intended as a distribution switch while the 3750 is intended as an access switch.
2) Etherchannel is bundling 2 or more links into one logical channel, it does not prevent spanning-tree loops.
3) Yes, you can use HSRP with the 3750 but keep in mind, with the stacked cable, a group of physical switches will be shown as a single switch in the CLI. In order to HSRP between 3750s, you need to have 2 stacks or 2 single switches.
